Having my rear wheels pushed out
troverman
Jun 9, 2015
1,178
266
NH
So my new MX4800 with ag tires appears to be about 70" wide measured to the outside edges of each rear tire. However, the rim dish is mounted on the outside of the rim lugs, and it appears the dish can be mounted to the inside of the lug...pushing the rim itself out another 2" or so on each side. I'd be happy to gain 4" of width for added stability on steep slopes I mow. The dealer is doing the work since the loaded tires are so heavy.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
You could go really wide, if you moved the wheels left to right, right to left, so the deepest part of the wheel faces away from the hub, instead of inward.
twomany
B7200
Jul 10, 2017
793
139
Vermont
Be sure to check with the manual on what spacing is admissible.
Too wide, and you run into load restrictions.
A fella can break just about anything if not careful! ;-)
TripleR
Sep 16, 2011
1,911
SE Missouri
I had my dealer extend mine as far as possible as I do on all the tractors we use on inclines. Your manual will show you how. When I was younger, my brother and I routinely changed spacing dependent on the task, but now I call farm service truck, just too dangerous for most.
troverman
Jun 9, 2015
1,178
266
NH
Yep, thought about this. But I decided to follow the manual and just move it out to the widest setting permissible by Kubota. Plus, unfortunately my trailer bed sits between the fenders...so even though fender to fender it is 102" wide the bed itself is only 82"...so that had to be considered too.
troverman
Jun 9, 2015
1,178
266
NH
Got it back from the dealer and now we are 76" wide...nice gain from 70". I'll definitely appreciate that on the slopes.
