Anyone Here Have an L4701 with a BH92? B2650 with a BH77
welnet
None Yet
Aug 23, 2018
Vashon, WA
If someone here has an L4701 with the BH92 Backhoe, could you tell me how high the top of the BH92 is for travel/parking? I'm trying to figure out how high of a garage door I would need. Would also like to get the same info for a B2650 with the BH77 Backhoe. If you could also let me know what type/size tires you are running.....
3,681
Mine (B2650 ROPS) fits under an 8' tall garage door with Rops up (R4 Tires). Not a whole bunch to spare, maybe and inch or two. I had to adjust the garage door opener to its max opening height.
You can drop the ROPS partway if necessary...and should fit under 7' door. That is IF you remember to do it. Mine measures 79" to top of half folded ROPS, 77.5" to top of boom at 15 psi in rear tires.
I believe the BH specs also state the height (at transport)...just checked. It states 80.7" (but they don't tell you what machine its on and tire type.
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
b2650 sitting on stock turf tires, the bh77 in it's pinned/locked position sits right at 81" tall. It's quite a bit lower than the top of the rops in the up position. Of course, you can unlock the boom and get it much lower to get thru an opening. Hope this helps.
fj40dave
Sep 24, 2009
421
256
Yelm, WA
7' Garage door.....my B2650 fits no problem
