Hi Guys,
New to orange talk and joined because of an issue I'm having trouble resolving. I am borrowing my Dad's L4330 GST for the summer for some work at my house. In return all he asks is that I fix the 3 point issue he's had on this tractor for awhile now. Easy right? He's owned this tractor since new and this is a problem that is slowly getting worse. I think its roughly a 2006 ish
The 3 ph will raise if I rev the engine up to around 1500 rpms or so but nothing at idle. The front end loader works perfectly and very strong, as well as the power steering. I am pretty mechanical and have read a few post online with people that had similar problems. I taken apart and cleaned about every relief valve on this thing with no improvement. I have located the power beyond line and appears to all be hooked up correctly with no kinks or issues with it. Oil appears to be in good condition and full. I have just replaced the spin on suction filter as well just to eliminate any potential issue. With a load on the raised 3ph is dosn't settle overnight so I don't thing the hyd cyls are bad.
My next step unless someone says different is to remove the top cover on the rear housing that controls the 3 point. Any more guidance? There have been many threads started on this issue but not a lot of them have been finished with what they did to actually fix the issue.
Thanks,
Joe
Thanks,
Joe
