L2501 HST 4wd
Bet
L2501
May 2, 2018
Union, MO
I have been leaving my tractor in 4wd all the time, is this a bad thing? I mostly use it to brush hog, till, and use the fel.
5,251
If you don’t need it don’t use it.
If you have good traction, 4WD can put extra strain on the front drivetrain, especially in turns.
With that said, I leave mine in 4WD almost all winter, but it’s usually icy and slick.
BAP
Dec 31, 2012
2,756
871
As long as you are not operating it on dry pavement you really aren’t going to hurt it. If you feel it binding in turns, then you should take it out because that means that there’s not enough give in the surface you are driving on.
3,315
MHO, leave it in 2wd until you need traction, then 4wd. Now if you are doing FEL work yeah 4wd might be a good idea. Other wise 2wd, your tractor will thank you, your tires will thank you, and your turf will thank you :D
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I only use 4wd when needed. I'd rather know I have extra traction available instead of going to far and not be able to get out.
This is one of my son's better moments. He said he stopped as soon as he knew he was stuck.
Newlyme
M4900 w/loader, finish mower, tiller, auger, rake. BX24 w/loader, backhoe
May 27, 2015
637
74
Nelson Ohio USA
No wonder he got stuck. There's no tread on those rear tires! :D:D
6,384
I have left mine in 4wd since the day I got it... Well they day I started running it after fixing it.
But I live on all sand and not really anything hard packed, no little to no wear. ;)
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
LMAO. It's a tractor, it will go through anything.
My machines stay in 2wd until 4wd is needed (That's Jeeps, trucks and tractors).
3,315
Yeah I found out early in my driving life, by the time your think you might get stuck,,its to late :D
troverman
Jun 9, 2015
1,188
275
NH
Generally speaking, using 4x4 only as needed is best.
On high-traction surfaces, like pavement, or rock, or concrete...the part-time 4x4 system of these tractors will bind upon turning and it puts a large amount of stress on the drivetrain. This is because as the front wheels turn, they are traveling at a different speed than the rear wheels (the inner wheels have a shorter distance to travel than the outer wheels). While there is a front and rear differential on each axle, there is no differential *between* the axles, and so no way to adjust for different speeds of the front and rear axles. When you turn in 4x4 on a highly tractive surface like pavement, your tires are forced to slip after the drivetrain binds. This is no different than the part-time 4x4 system found in many modern pickups. When you are on slippery surfaces such as grass, dirt, snow, etc...the slipping still happens...but it happens very easily with virtually no binding or stress on the drivetrain.
When your tires slip (and it usually is always the front tires to slip since they are smaller and gain less traction)...they wear. So although if you leave your machine in 4x4 at all times more than likely nothing will actually break...the tires will wear much faster.
I wish Kubota would offer a 4x4 indicator on the dashboard, but they don't on most models.
Bulldog
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Bulldog, about the only thing to make it more fun would be if he had a belly mower on it!!:D:D
It was sitting on the loader subframe and that was with the box scrape lifted all the way up.
Of course he gets it honest. This is when I almost turned over in the pond.
Bulldog
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Took my neighbor about 20 minutes to get there. I'm glad he got there when he did because it was still sinking.
Mister
130
Northwest
I take it you fellows haven't seen the other thread, where the guy lost all braking power, because he was in 2WD and didn't have enough weight in the rear? There's more to 4WD than traction. Strangely, it also effects braking
Sent from my SM-N950U using Tapatalk
