Rpm
RockinJ
Kubota L3240 Grand HST
Sep 29, 2017
Shawnee Oklahoma
L3240 Brush Hogging RPM keep dropping
Started brush cutter today ran great first couple hundred yards then RPM went to 1000 just in split second turn PTO off stop RPM run good start up again 100yards same thing happened repeat repeat loaded up went to dealer sucks help please FUEL ???? be using Diesel Kleen each time adding fuel from now on !
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
Re: L3240 Brush Hogging RPM keep dropping
Sounds like a fuel issue. How many hours, how often do you use it, when did you last change the fuel filter?
RockinJ
Sep 29, 2017
Shawnee Oklahoma
Around 255 hours first time using rear pto since last fall also had winterized all fluids filters changed at that time , I’ve used it couple hours since then just dragging blade low speed until brush hogging yesterday. Figured crap in fuel ***9981;***65039;
6,620
Sound like you need to drain the tank, change the filter, and treat it for algae. ;)
JerryMT
Jun 17, 2017
528
156
If you don't use this tractor often, you need to keep the fuel tank as full as possible between uses to minimize bacterial sludge (often call "algae")). The root cause of this fuel contamination is water in the fuel and the most likely source is from water condensing on the walls in the partially full fuel tank (assuming you don't leave the cap off the tank or bought contaminated fuel, etc). Certain bacteria live in the fuel/water interface eating the fuel and causing the sludge to form. This is especially true in high humidity environments.
So keep your tank topped off as much as possible to preclude this.
