Old B 5200
6,986
Wiring diagram would be found in the WSM (AKA service manual)
I can't find a free download of that manual.
P/N 97897-10713
What is the problem with it, they have very simple wiring, and someone on here should be able to help you work out a problem.
2,600
Someone has cut up the wires for whatever reason, I need to get them out back like they should be
ok....stupid question.....what is not working that you wish ?
Lights?
OR???
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
X2
NIW or others can help, take some pictures and post them up to get assistance
To help yourself get started you may wish to download a service manual for a B5100 and B6200 which "should" be similar. These wiring diagrams plus pics will help you/someone sort it out.
Harlin Huskey
Kimberling city mo.
Well I have new weatherpac connections coming I plan at this point is to go through wire by wire and trace and test each wire. I have found some of the problems such as no power from starter to switch and the list goes on and on. Thanks to all
