Rear hydraulics - HELP!!
aerolland
B2150
Mar 6, 2015
57
Morganton
I have installed this 3 spool valve after the loader spool and before the rear 3 point control.
https://www.surpluscenter.com/Brands/Prince-Mfg/3-Spool-8-GPM-Prince-MB31BBB5C1-DA-Valve-9-7863.axd
I made sure it's in power beyond configuration, I do have 3 point control so it should be correct.
The problem I have is I cannot control rear cylinders. It bogs does and clearly is going across the wolverine pressure relief valve. If I put dummy quick connects in any of the 3 paired rear remote lines and activate the corresponding spools, I get fluid on BOTH working ports! How can that be??
Sent from my SM-G955U using Tapatalk
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
"Open Center Convertible to power beyond or closed center"
So you put plug in the correct place, as well as P in/PB out/tank hoses correct?
aerolland
B2150
Mar 6, 2015
57
Morganton
So I figured I would post the follow-up solution in case anyone was experiencing similar.
...no judging now...it's extremely tight in the spot I picked to install the valve :)
I had the Pressure and Power-Beyond connections swapped, therefore, fluid successfully passed through the valve backwards and would operate the 3PT controls, however, asking for rear hydraulics dumped pressure to the Tank gallery. Ooops!
aerolland
B2150
Mar 6, 2015
57
Morganton
Excellent! And now is the time to mark or color code things while fresh in memory.
I kept it simple, left to right ports match left to right sticks.
Up on stick pressurizes top port, down on stick pressurizes lower port.
