Will Not Start Now
lwamhof
L2250
Mar 31, 2011
Madera,CA.
L2250 Kabota..Tractor would not shut off. Replaced Relay,Solenoid and Key Stop got started once now will not restart. I charged the battery,now when I connect the battery turn the key, dash lights come on then turn key to start hear solenoid click then nothing! Try again no dash lights,Acts like dead battery, repeat process same result. Any Ideas?
ametcalf
BX23
Apr 9, 2011
17
Wilmore, KY
Even though you charged the battery, it still may be giving you problems. I would try to put the battery under a load test. I had the same problem with my Allis 5040 about a month ago. I thought the starter was out because I charged two different batteries (the one in the tractor and I borrowed the one off the boat) and both would only make the solenoid click. I put them under a load test and both showed bad. I got a new battery from Wal-Mart and the tractor started right up and has worked well ever since.
ametcalf
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
If you have not done so already,make sure the two battery leads are clean and tight at both ends and the battery is fully charged.This should be a good starting point for all electrial faults and is often overlooked.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Agree with the others. Seems like not enough amps are getting to the starter.
Make sure the posts/connectors are clean and there is a good ground. You can eliminate the possibility of wiring problems by using an automobile jumper cable to directly connect the battery to the solenoid and the ground post to the starter.
If your charger has a "start" setting (high amps) give that a try. It should kick over the tractor with no problem.
Sam's Club has the large, 200 amp, multi-function charger for about $80.
GWD
Jan 8, 2010
792
17
Northern California
OE stands for Original Equipment. The battery cables may be going bad.
That is where using battery jumper cables would bypass the OE wiring and determine if it was faulty. Of course, connect directly to the battery posts rather than the OE cable clamps.
