Do any of you have an accurate tire pressure gauge?" If so, would you mind posting a photo of it with a link as to where you obtained it.
Thanks...
Thanks...
Some of those "sticks" are good ....some suck!Do any of you have an accurate tire pressure gauge?" If so, would you mind posting a photo of it with a link as to where you obtained it.
Thanks...
How fast are you driving that thing!? Does it have a big #3 painted on the side? It's a tractor. I like to be as close as I can on stuff of that nature as well, but if you have gauges around the shop and two of them read within 10% of one another then either one would probably be good enough to keep EXTREME, premature tire wear to a minimum.Do any of you have an accurate tire pressure gauge?"...
Thanks...
It's will be used on automotive vehicles as wellHow fast are you driving that thing!? Does it have a big #3 painted on the side? It's a tractor. I like to be as close as I can on stuff of that nature as well, but if you have gauges around the shop and two of them read within 10% of one another then either one would probably be good enough to keep EXTREME, premature tire wear to a minimum.
Here is the one I use; old, like me but really hard to find better, like me. LOL https://www.ebay.com/itm/Vintage-AC...accu+gauge&_from=R40&rt=nc&_trksid=m570.l1313It's will be used on automotive vehicles as well
I would like to get one that doesn't have a battery, or at least one that uses a standard AA or AAA battery.
That's funny, "vintage", I have that one too and got it around 1991 when I got my Early Bronco. It's still going strong and is kept in my Rubicon. It's nice that it has a relief button that you can lower the pressure a little with if you get it too high. I'm vintage too, but hadn't thought of mine as vintage before.Here is the one I use; old, like me but really hard to find better, like me. LOL https://www.ebay.com/itm/Vintage-AC...accu+gauge&_from=R40&rt=nc&_trksid=m570.l1313
Mine only registers 60PSI which I prefer. I think any type of gauge, regardless of the application should never operate near the extreme range borders; either high or low. Meaning dont use a gauge that will accommodate a 300 psi supply to try and accurately check a tire with 14 psi pressure.
