I am installing some gauges and I just put in a amp-gauge and when the tractor is running at idle with the lights on the needle dips to the negative side and stays there until I rev it up. I have an older type B7100 with the alternator behind the fan, it's the two wire type. When I measure the output it reads 8 volts AC at idle, this seems low to me, does anyone know what the AC output voltage should be at idle?
