wrong oil in my bx
gearjammer
2019 bx 23s 2017 road king
Mar 7, 2018
17
boonville ny
was changing my oil ran out of Kubota oil and used a quart and a half of motor oil will it hurt my tractor engine
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Well in this case the devil is in the details....which oils did you mix?
In general as you probably know already it is a bad idea to mix oil types. Furthermore, oil for diesels is different from that used in gasoline engines. Some oil is better than no oil in an emergency. Sounds like you'll have to change oil and filter again asap.
3,051
was ganging my oil ran out of Kubota oil and used a quart and a half of motor oil will it hurt my tractor engine
I'm with Sheep......can be a little more specific?;)
gearjammer
Mar 7, 2018
17
boonville ny
ok I was changing my oil in my bx 2360 thought I had enough Kubota oil but didn't and needed to use it so I added some 10 w 40 motor oil just about a quart and a half started it since then sounds alright just wondering if I hurt it I am going to change filter and oil again asap with rotella
rentthis
1,010
25
summerville,sc
Personally, I would use it as is. If you change the oil, I see no reason to change the filter. It's already mixed with the Kubota oil and holds very little oil in the filter. You might check the extra oil you added. It might be diesel rated. If so you have no reason for concern.
kevinj
L3940hstc - B7500hst - BX1860 - Farmall 560D - Farmall M
Jun 4, 2018
102
You still have not said what type of oil you added?????
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
Are you changing the engine oil or the hydraulic oil?
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
If it were mine and I put 3 litres of mineral diesel oil 10W30 in it and 1 litre of 10W-40 mineral gasoline rated oil in it, it would not be a concern to me. Why, most gas oil is also diesel rated to CF or better these days, which is all yours needs.
But what everyone is asking here, so they may give an evaluated reply is the oil specifics, meaning Brand, Type and weight of both oils used. Also if they are mineral or synthetic.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Everybody would still like to know what you used, but here is the spec for your model. So you can just about throw any standard multigrade in it!
Engine oil : API Service
Classification CF or better
Below 0 °C (32 °F) : SAE10W, 10W-30 or 15W-40
0 to 25 °C (32 to 77 °F): SAE20, 10W-30 or 15W-40
Above 25 °C (77 °F): SAE30, 10W-30 or 15W-40
3,051
was changing engine oil and used 10w 40 oil
I think everyone would like to know if you USED a diesel oil or a "gasoline" oil.
There is a difference, but for the short haul - you do not have a problem, personally, pull the plug, drain the oil and start back with your machine demands.
nothing hurt;)
gearjammer
Mar 7, 2018
17
boonville ny
it was gas engine oil 10w30 just drained it put rotella in ran it a bit drained it again and put new rotella in im sure its ok I think
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
Your engine will not even know the difference..... it does not read the oil-label and will be ignorantly happy with pretty much any lubricant which meets the requirements.
If *YOU* are concerned, after 10 hours or so, change the oil again (leaving the filter on) with the "kubota oil" of your choice to make *YOURSELF* happy.
twomany
B7200
Jul 10, 2017
793
139
Vermont
Actually, Nobody cares what little bit of "other oil" you might have added to your "Kubota oil". I mean, do you think Kubota actually MAKES OIL?
They do not, they merely buy oil from some source and put it in "Kubota" labled bottles. Read the spec, and use ANY OIL with equal specifications.
Unless you put castor bean oil in with the petroleum oils available 99.999% of the options, You are good to go.
Cripes! When is the last time you even heard of an engine failure due to oil brand or type?
Someone will say they "saw" three in the past 10 years, but they work at a service facility and the back story is buried in the bushes,
YES< Motor OIL IS THAT GOOD!
Botabob
B2410-drag,box blade, trencher, plow, boom lift, bucket forks, bucket hitch, 3-p
Jan 17, 2018
Boynton Bch, Fl. usa
I'm sure Kubota will tell you to fluch it and put kubota oil in it. Know where are the Kubota oil wells? when I told them I wanted a front end loader for my tractor, they told me to get a new tractor. i would love to if they would take $20k off the price.
10,963
I think this thread has gone a little off the rails! :rolleyes:
You didn't do any damage using 10-30 or 10-40 gasoline oil of any brand name in it.
Rotella is a very good choice, I use it in all my equipment, never an oil issue. :D
Your filling and flushing is way more than you really needed to do, it's good and its done, so now just run it till it's due for another oil change and don't look back. ;)
