I recently bought a 3 point hitch, Land Pride, RCP2560 "boom mower" to use with my M7040. Hooked it up and it worked perfectly but...I have to keep hand pressure on the control lever to keep pressure going to the remote. Is this normal? Keep in mind, the PTO runs the bush hog so that isn't tasking the tractor hydraulic system. It almost appears the hydraulic system isn't putting out enough volume or pressure to run the different cylinders of the boom mower. No other hydraulics are being used at the same time. Any help would be appreciated.
