You're doing a whole ton of assumptions!This is a brand new machine and now you have nothing for possibly months because somebody at the dealership FUd and didn't put in fluids or tighten bolts etc.
If you are driving down the road and the front end suddenly locks up wouldn't you expect undue stresses and strains on the rest of your machine parts? You don't know the extent of the damage that has been done.
The dealership needs to man up and give you a new replacement machine. You pay them good money for a brand new machine and now you get stuck with a lemon after 8 hours of usage. I'd be livid.
I feel your pain Toby3294.
If they don't give you a new machine I'd be posting the dealership's name online here to warn other potential customers.
You don't know if it did or did not have fluids and the dealership does not work on any bolts in the front axle, so that rules those two right out.
And as kevinj pointed out, it was in 2wd when this happened so no damage would be done to the rest of the tractor.
It's a simple case of a part went bad, it happens.
It also a simple fix, I would say the dealership went above and beyond to get an entire new axle for it instead of putting parts into it.
And they jumped right on it to find out what went out in it!
When you buy a auto, tractor, or just about anything else, they give you a warranty to cover situations just like this, demanding a new one just because a part failed (that can easily be replaced) is a little over the top.
