Snow Removal Loader Damage
Wildfire
Some more pics. This is how the original poster should do his bucket to save it from further damage. First pic shows how the carriage bolts look under the bucket. In the last photo you can see the row of nuts along the top of the cutting edge.
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
Paul, thanks for going into detail and providing pictures on the new cutting edge for your bucket. I have a question after looking at the pictures. I'm guessing that you used 3/8" or 1/2" steel for the cutting edge. And it looks like you tapered the edge of the steel. How did you make the taper? Some years ago, I built a backhoe bucket and made the cutting edges on the sides by grinding them down with a grinder. It was slow. I know there has to be a better way. Thanks!
Wildfire
Pat I used 1/2" for the cutting edge. The material came with the edges tapered like that because It is 1/2" X 6" flatbar. That being said I do intend to put an edge on it plus use hard facing to keep it from wearing later this fall. Although I'm sure you did a great job by grinding your bucket to get your cutting edge I'll use my milling machine to do mine. This cutting edge is 73" long and grinding would be a long drawn out process.
When I go to do this I'll post photo's if you like. No need to thank me. That's why we hang out on these forums, so we can learn from one another.
Here's a few photo's of the milling machine:
pat331
Mar 31, 2009
298
Ft. Worth, TX
Thanks! I've never used a milling machine. It would have made short work of the work I did with a grinder. I'm looking forward to seeing photos of this operation when you get to it and photos of the hard-facing you do to the cutting edge.
Eddie Jr.
B3200 HSD
Mar 27, 2011
152
Ottawa Valley, Ontario, Canada EH!
Wildfire, you rock bud! Awesome job, and you answered the second question I was going to ask about how to make the square holes. Nice job!
Thanks again for all the pics and info. I will be doing this to my bucket for sure before winter hits again even though I am considering a rear mount blower, still be great to have to save the bucket.
I love this forum!
M.
Wildfire
I love this forum!
M.
Your more than welcome. I went with the rear blower on mine and love the set up. The blower adds ballast for the FEL. I find the set up perfect for my needs. I have the skid steer quick change attachment on the FEL so I can switch from to bucket to the blade in no time.
Not sure if the link will work because I'm sending this via my iPhone.
http://m.flickr.com/#/photos/15602393@N05/5650124825/
Eddie Jr.
B3200 HSD
Mar 27, 2011
152
That was the same reason I want the rear mount. The front mount blowers look like a lot of work to change back and fourth from the FEL. My dad has the front mount on his B2620 and it looks slick but I am still going with the rear when the time comes.
Got the pic, link worked from the phone. Are those "potholes" at the top corners of the cab? "Hot Rod" again? ;)
M.
Wildfire
M.
I leave my snow blower on all the time but as I mentioned before I only use the tractor for snow clearing but the blower is a great way to have ballast in the rear. I did get the factory ballast box with mine but never used it.
Ya I seem to get this Hot Rod feeling on every machine I have. One of my weakness's I guess :eek:
Eddie Jr.
B3200 HSD
Mar 27, 2011
152
Nice! Love the little louvers on the back of the forklift! Moon-eyes on the mower! Hhahah Well done! ;)
So I mentioned the cutting edge to my buddy that works at the steel place up the road and he said "Oh listen man, you want some T1 for that" Stuff is super durable apparently just had never heard of it before, I assume it is a grade/quality of steel that will last well for the cutting edge. I might even talk him into cutting the difficult looking square holes for me.
Ever use any of this stuff in your work Wildfire?
Thanks!
M.
Wildfire
Thanks!
M.
Yep I've used it but I refrained from using it this time and for one reason only. I was afraid that it might damage my punch and die for my ironworker. I have a set of them and they cost me $160. each and I didn't want to spoil the one in that size. I attached a few photo's of one lot of punches I had ordered. Now remember this is not the complete set. I have about 40 different punches and sizes and this is only one small order :eek: My ironworked will punch holes up to 1" thick in mild steel and I didn't want to chance it with the harder metal. No matter what you use for a cutting edge it will wear but the harder the metal the better it will be and last longer,
My plan is to use hard facing to protect the edge. I have the hard facing here for another job I'm doing so I'm basically doing it for zero cost which is good :D
Ya everything is pimped out around here. Da wife says I can't leave anything alone ;) Here's a vid and an article on the old forklift.
http://www.forkliftaction.com/news/forklifts_news_international/Specialty_Repairs_7183.aspx
http://forklifttrainingblog.com/forklift-training/toyota-forklift-restoration/
