Bent top link?
skinnypez
B2650
Jun 23, 2018
Missouri
Hey all...very noob tractor owner here.
Dealer dropped off my B2650 with Rotary Cutter attached after mentioning at the dealer during their educational walk-around after we purchased that it was ready to use.
I mowed about 4 acres of level ground with no ditches or anything and then parked the tractor in garage with rotary cutter lowered so the tail wheel was on the ground.
When I went to back the tractor out of the garage today to move some stuff with the loader, I noticed a slight angle in the top link; I was very going very slow when mowing and like I said, there are no ditches or anything too un-level on my land that I think would have caused this...perhaps I shouldn't have parked it with tailwheel on the ground?
I guess my first question would be is this bend in the toplink a big deal if I'm only going to be using a rotary cutter on the rear for the foreseeable future? Second, any ideas what might have caused this damage?
Thanks for any assistance you can offer!
3,358
1,795
Raise your three-point and I think you will see that the centerlink hit the ROPS which you have folded down.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
You have your rops folded down. The top link hits the rops when lifting the 3point hitch. Thats what bent your top link. Its a poor design
Yup what he said. Happened to me and my neighbor also!!
skinnypez
B2650
Jun 23, 2018
Missouri
Ah...yes...my dealer even mentioned that on the walk-through...pity I didn't remember until now!
Thanks for the quick replies.
Anybody have any recommendations on brand or where to but replacement? I know Kubota replacements are stupid expensive...my dealer mentioned that, too.
3,358
1,795
Complete assembly from Coleman Equipment is $52.77. I really would not call that stupid expensive when the "will fit, kinda work" ones will be $40.00 or more.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
yep you hit the folded ROPS....
has happened to many of us here ... including me.
go to tractor supply or rural king & buy the heavier one for $19 & paint it orange if it bothers ya. :D
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Glue a couple of rubber blocks onto the ROPS so when it folds down it rests on the rubber blocks and doesn't come down as far and will stay out of the way for your implement.
skinnypez
B2650
Jun 23, 2018
Missouri
$52.77 isn't too bad at all- for some reason I was thinking he was talking $100+...I will check out Coleman for sure
bcp
BX2360
Apr 20, 2011
644
80
SW WA
About 5 years ago I did that, but it bound on the top link adapter on a quick hitch, that I had left flipped the wrong way when not using it.
I took the top link off at the rear, turned it over with the top link bend turned the other way, and carefully repeated the lift to bend it back straight.
Still using it and it works fine.
Bruce
200mph
Mar 3, 2017
1,228
65
PA
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
stick a hydraulic top link in there. For a hundred bucks or so you can adjust on the fly. Worth its weight in gold when box blading.
Oct 8, 2014
616
oregon
X2 but you will need to have hoses made up too. I used fuel line to mock up the routing and length. 90's off the cylinder worked well.
johnjk
Apr 13, 2017
1,727
1,974
West Mansfield, OH
Did the same on my B3200. Dealer neglected that and most other operational aspects when I bought my B used. Now with my new shade, I do not put the ROPS all the way down but still need to purchase a replacement from Rural King or TSC. I use a quick hitch out back and was able to dial it in to the position I need and lock it down so not too worried about having to adjust it now. Will need that feature when I start using my box blade.
I like the idea of the hydraulic link, but would I need to run additional controls on my B for that?
