L5740 info
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
I am looking at a 2013 L5740 and was told by the owner that it does not have Tier 4 emissions nor does it use DEF or any filters.
Can anyone confirm if this true as I thought after 2012 all machines were T-4?
SDT
multiple and various
Apr 15, 2018
3,399
1,181
SE, IN
Confirmed. No DPF or DEF.
SDT
mickeyd
Mar 21, 2014
1,192
Guin, AL
Not true. Maybe the law was passed then but the Tier 4 tractors didn't appear until 2014.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Tier IV is a standard, and does not specify what equipment will be used to meet it. In 2013 the new Grand L 60 series were for sale and did use a dpf filter to meet that standard. That is when I bought mine. There were still available earlier versions of L tractors. The year of a tractor is the year it was sold, not the year it was made.
TripleR
Sep 16, 2011
1,911
SE Missouri
I traded my L5030HSTC, great shape, in for a new L5740HSTC to avoid the final Tier IV L60. The L40 series had Interim Tier IV engines, some added turbos for emission control and the injection system was modified making it smoke and rattle more than the L30 Series. No L40 was Tier IV Final.
200mph
Mar 3, 2017
1,228
65
PA
ROPs or Cab?
TripleR
Sep 16, 2011
1,911
SE Missouri
Check on Tractor house, but hurry or it will be gonr these things go quickly. Be sure to check for leaks espcially aroundd the split wring to drain water out of the clutch housing.
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
The tractor is 6 hours away and getting out there will be difficult.
The seller will arrange shipping.
Other than from photo's and the limited info the seller, who is a used equipment dealer, apparently has, I have no way of assessing the machines actual condition.
Has anyone bought a tractor sight unseen before? Bad idea?
Oct 8, 2014
616
oregon
I did but super low hours and I'd been talking with the gentleman off and on for over a year. With 1500 and knowing what I know now I'd go look at it. Fluid and filter changes can add quite a bit for one thing.
7,265
I'd only buy the tractor if I saw it in person. Simply because you're not spending $2,000 on an old tractor, you're 15 times that!
What's described as "no issues", or "nice and clean", or "recent service" is not really measurable, only someone's opinion. Example: Someone says "recent service" and one person thinks that means last weekend. The other person thinks it means within the last 6 months.
Take the time to SEE what you're buying so you'll be happy when you use it!
200mph
Mar 3, 2017
1,228
65
PA
I’d spend the time and effort to go look at it and test it out before spending $30k.
Servicing can be expensive. HST Fluid is $300+, oil filters another $100+, air filters another $100, plus the cost of motor oil $50. You're looking at Approximately $600.
Tractors seem to be more expensive expensive in your neck of the woods, but there should be some room to negotiate on price.
Does it come with any optional accessories. Rear defogger, side defogger, rear wiper, mid PTO, etc.
I had bad tie rod ends on my L4740 so you might want any to check them out. Lift wheels off the ground using FEL and move wheel in and out. Easy fix but another $250 assuming you’re doing the work.
200mph
Mar 3, 2017
1,228
65
PA
They were bad at about 525hrs, but put off replacing them until about 600 hours.
After removal I cut them apart and could believe how bad they were. I did create a post about it either on this site or the other tractor site.
