Bi-Speed Turn Lever on a B1700
J.Schiefelbein
B1700HST
Jul 28, 2015
Kranzburg, South Dakota, USA
Is there a procedure for using this?
I ask as the lever does not want to budge from the off position, I read the manual but it didn't imply I would need to do anything special. So far I have gotten by with out, but would like to use on occasion.
ryansmoneypit2
B7100, 48" snow blower, woods rear blade, crappy front blade, 64" mower deck
Mar 2, 2018
29
virginia
Bi speed? thinking you mean Hi- Speed? Clutch pushed in, pull hard.
SDT
multiple and various
Apr 15, 2018
3,316
1,102
SE, IN
The Bi-Speed Turn lever on my B1750 moves easily between On and Off, and I use Bi-Speed regularly when mowing.
Have you tried moving it to the On position while moving forward and backward on level ground with the steering centered?
SDT
J.Schiefelbein
B1700HST
Jul 28, 2015
SDT
I tried forward, backward, turned, not turned, neutral, high, low, and off the lever doesn't want to budge.
I don't want to yank too hard and break something. but have always wondered what was wrong or if it is something I am doing wrong.
SDT
Apr 15, 2018
3,316
1,102
SE, IN
It should engage/disengage easily.
Check the linkage for evidence of binding, corrosion or damage.
SDT
