it is a place to put a ratchet left Side bottom and also on the left side end is a adjustment that moves the knurl solid cylinder closer to the smooth cylinderCan you get a couple pics from other angles?
Is that a socket on the bottom portion of the picture?
Does it except a ratchet on top?
If yes to question 2 and 3, then I would think it's a torque multiplier. But this is a guess off from the small screen on my phone.
Sent from my SM-G920V using Tapatalk
Is it a Snap-on tool? can't make out the stampings on it, if it is go to Snap-on and enter the Part # and you'll know what it is used for.it is a place to put a ratchet left Side bottom and also on the left side end is a adjustment that moves the knurl solid cylinder closer to the smooth cylinder
Sent from my SM-S727VL using Tapatalk
