Need help
hillbilly162
1993 b7100
Nov 23, 2014
40
mount pleasant pa
Hello guys I got a 93 b7100 hst 4x4 with a 18 HP motor in it I'm looking to get a brush his attachment for it would 4 or 5 foot work on it.
Also another? Can anyone tell me where I can get a 4x4 Front end for this from had a part break in it and they want 900 for part any help be great
7,819
A B7100HST is 16HP engine but only 13HP PTO, keep that in mind for implements.
The entire front axle for a b7100 will probably run you far more than just one part.
2,809
coachgeo
Nov 16, 2012
2,460
37
Southern OH
I put a 18 HP eng in it last year cause the other one went on me and I was hoping to see if a brush his would work for it
while the bigger engine will give you a smidge more HP and torque here and there..... it will open up more chances to break things as well. granted if the gear box components etc. is also used in later Higher HP tractors then your probably fine. Should probably check into that first though.
