I got a quick hitch. Now one of my implements shafts is too short!
What is some of my options, can I just get a longer PTO shaft and mount the slip clutch to that shaft or do i need to get another shaft with a slip clutch?
Thanks D2Cat I'm still a little too short even with that. When I measured I'm short about 4 inches.Maybe just use one of these. https://www.tractorsupply.com/tsc/product/speeco-pto-extender
That would work, thanks. Honestly I took a look at this yesterday and it didn't even hit me that it was 4-3/8 inches.It extends the PTO shaft by approx. 4-3/8". Quick Release.
https://www.amazon.com/Extender-Adaptor-Female-Quick-Release/dp/B06XGW2P8N/ref=pd_sbs_86_2?_encoding=UTF8&pd_rd_i=B06XGW2P8N&pd_rd_r=ZN7C8Q0FNCXVFYPC05N0&pd_rd_w=XjipQ&pd_rd_wg=Pqe7B&psc=1&refRID=ZN7C8Q0FNCXVFYPC05N0
Ramos thanks, I was thinking the same. I wanted to know what my options were.PTO shaft extenders introduce a lot of stress and leverage at the tractor end and are responsible for many broken output shafts. They also put your pivot point in a location that neither the tractor, nor the implement were designed for. Get a longer driveshaft. If you match the tube size and style, you can reuse your ends if they are not welded on.
