B9200 HST 4WD Hydraulic Issue continues
After three HST flushes, the watery crappy fluid is fixed. I took the tractor to local small engine repair shop and they were completely useless in diagnosing my inability to operate the tractor up a hill with a load or in any other range besides low.
I’m doing the deep dive into the hydraulics. I turned the directional nut all the way clockwise and the FLE completely stopped operating. I backed off the nut little and it worked again. I think the FLE hand control is Plummer wrong. A diagram or schematic would be really helpful.
Second, the lift arms are in the up position and stay there. I can’t put a load on them because the PTO driven BH is in the way. The position control lever is locked in the full up position. When I put it down, the tractor wouldn’t move unless I operated the FLE (again, WTf?)
Lastly, the lift arm speed knob is in the locked position and I haven’t messed with it.
The repair shop “guessed” I have a weak pump. I purchased a 3000psi gauge but need a few more fittings to plug it in.
Again, I’m at a loss here. I can’t find the hydraulic diagram for the FLE and believe I have a relief valve issue and/or a plumbing issue. Once I get that set right, I will look harder at the potential “weak pump”.
