Late 80s Kubota L3750 4wd hydrostatic shuttle
Dec 17 pressure testing my mechanic found the source of my problems (low/slow/no loader power) to be my priority valve. we replaced it with an oem priority valve ($523). The old unit was non oem, this is at least the third priority valve. At that point I was concerned there was another reason for the failures
symptoms have returned less than 6 mos later, now worse, also with slipping hydrostatic shuttle (fwd/rev). total loss of power at loader and 3 point lift
I found where someone else had a problem with a similar priority valve and fixed it (http://www.orangetractortalks.com/forums/showthread.php?t=21591) by filing down the plunger within the valve
However in my priority valve, the plunger im pretty sure is non servicable. It is housed inside a plug. (photos attached of my priority valve diagram, actual non oem priority valve removed from my machine, plug containing plunger/moving parts of priority valve)
What are other causes for priority valve failures. I changed the hydraulic oil at the time of the last one. Could it be a pressure release valve issue? Looking for common causes of priority flow valve failures. If nothing else is there a method to bypass or install a priority valve from another model. Any suggestions appreciated.
