I have only about 20 hours on my BX, and was just now checking the fluid levels. When pulling the yellow plug on the front axle, I noticed there was no grease on its short dipstick. Inspection with a light showed there was grease, but it down there a bit. The internal drive axle is visible and perhaps the bottom of the axle is touching the grease. Does this seem low?
The manual says the axle takes 3.8 qts of 80~90 wt grease. Should this amount register on the little dip stick on the plug? The housing size indicates it has a fair amount of volume, but I'm not sure exactly how high the level should come when filled with 3.8 qts.
Any BX23S owners, if you get a chance, could you check this for me? Take a peek in the hole and tell me where the grease level is with respect to the internal drive axle and on the dip stick.
Much appreciated.
BTW, the tractor is of course sitting level.
Much appreciated.
