I was thinking about getting a top-n-tilt kit for my L6060. However, I believe that the Kubota kit won't work if you have a backhoe subframe because the side tilt cylinder would hit the subframe. Kubota won't let you order a tractor in this configuration. Has anyone tried this? Maybe an aftermarket TnT kit might work? Worst case, I could use a top cylinder only--it would still be a big help. Thanks for your advice.
