I just bought a Leon 490 FEL that I'm planning on putting on my L1500DT. I'd appreciate any pics that anyone has of their sub-frame, particularly showing how it gets around the front and rear axles.
Should have been more clear in the original post. I'm looking for pics of loader sub frames of any L1500DT, particularly around the front and rear axles. Frame and bracket pics from L1501DT's L185DT's and anything else that might be pertinent are appreciated as well.I think your going to hear a lot of crickets..that's a rare setup.
And I should have been more clear as in I think your one of a very few that have a L1500DT, most on here that have a L1500F (2wd version).Should have been more clear in the original post. I'm looking for pics of loader sub frames of any L1500DT, particularly around the front and rear axles. Frame and bracket pics from L1501DT's L185DT's and anything else that might be pertinent are appreciated as well.
The tower mounts should not need to be tied to the front bracket necessarily, but the tower brackets do need to be attached to the rear axle via axle bars.I have the tractor stored offsite so I can't get measurements from that today. I have the rear bracket which measured 32 1/4 on the inside of the brackets that bolt to the bottom of the towers. The front bracket is with the tractor but it's about 28 inches wide as that's what the frame that fits inside the booms measures. The driveshaft is less than 13 inches from the center of the tractor because it's inside the muffler and that's about what the muffler measured. Staying outside of the driveshaft shouldn't be an issue until I need a tie it into the front bracket.
There are 2 l1500dts here with FELs on them if memory serves.
You forgot about Bill he's an active member with L1500DT with FEL. Might be tied up at the moment, but I'm sure he will jump in when he see's the threadI think your going to hear a lot of crickets..that's a rare setup.
Yep did forget about Bill... Great pictures Bill!
I wonder if I could get a close up that shows where the hydraulics are tied into the Kubota system.
Here are some shots of mine during the rework,
let me know if you need me to take any more
specific areas not shown in these.....
Here's a picture from bill in my auxiliary hydraulics thread showing his block for the tie inI wonder if I could get a close up that shows where the hydraulics are tied into the Kubota system.
This thread will show you the block and who to contact for one
http://www.orangetractortalks.com/forums/showthread.php?t=32751&highlight=Auxiliary+hydraulics
