FINISHED switching My 2009 B3200 from low amp Dynamo to Kubota 40 amp alternator
My 2009 Kubota B3200 came with the little 10-15 amp dynamo and external regulator. I always try to run the tractor long enough and at medium engine RPM to get the engine hot enough to keep moisture out of the oil and to keep the battery charged. A few times when I was running slow engine speeds with my 4 way flashers on and headlights on, I ran into a low battery upon restart.
I researched the Kubota USA parts microfiche and in the front after picking what tractor I had, I looked up the "OPTIONS" page. There I found that the 40 amp alternator was an option kit for the B3200. The "Kit" is no longer available but the page that showed the kit gave the part numbers of the parts needed to convert. You have to change to the different engine oil dip stick because the one for the Dynamo won't clear the alternator.
The wiring loom is no longer available but that is not an issue for me as I have many years of automotive and equipment wiring experience. I will make up my own wire loom and use the dash dynamo light as the alternator light when the ignition is turned on. I may have to isolate the alternator light wiring at the instrument cluster from the rest of the indicator lights but I will see when I get to that. I will also use a 12 volt CUBE LOAD Relay to keep the extra 2.5 amps the alternator takes to energize it off of the ignition switch. The nice part is that the Kubota, Nippon Denso alternator is INTERNALLY REGULATED, meaning that the voltage regulator is built in on the back of the alternator.
I found the New Old Stock Kubota/ND alternator on ebay for $85 plus shipping. Another seller had the same alternator but wanted $235 dollars! pays to search. You can buy the cheapo Chinese knock offs but I got lucky and found the OE part. I also had to find the "T" shaped plug for the back of the alternator. I found it on ebay for about $8 bucks. Only issue is that the female push on connectors are very thin. I bought some thick gauge ones from an electrical supplier so I will just use the plastic plug and make up my own wires when I make up the Alternator wiring loom.
I WILL post my work on the conversion with pictures. The picture show the parts I got from my local Kubota dealer and the part numbers. The parts were just under $100 shipped to me and I am into the alternator for about $100.
