How do you avoid corrosion in diesel tanks?
I have owned my 2003 M9000 Diesel Tractor for almost 2 years. After roughly 14 months of ownership I started to encounter what appeared to be a fuel starvation problem. The problems normally appeared when the tanks were below 1/2 full and I checked to make sure the fuel gauge was working properly. After having this problem a few times I removed the fuel tanks and discovered a thick layer of sludge/debris in both tanks and concluded this was causing my problems. After tank cleaning/boiling I started to encounter the same problem once the fuel level dropped below 1/2 full. I dropped the tanks and found additional rust/corrosion in the fuel. I have ordered new tanks but I'd like to avoid this problem in the future.
As a side note, since my ownership, I have fueled the tractor with fresh and clean off road diesel from a new plastic storage tank. This fuel has also been used in 3 other machines with no problems with the fuel system.
