B2601 correct hydraulic pressure?
GreenMtns
B2601, 4' Frontier Rotory Mower, 5' King Kutter Finish Mower, 4' King Kutter Rot
Apr 13, 2017
9
Western Vermont
What is the factory hydraulic setting suppost to be on a B2601? 2000 or 2500?
Thanks
Al
2,897
Thanks
Al
Without looking it up .......I would "guess" closer to 2000, on the BX series, it comes factory around 1800 ish - bumping it to 2000 is about safe max.
What are you reading now? I did read that many are using a PSI closer to 2400-2500 after shimming.
GreenMtns
Apr 13, 2017
9
Western Vermont
Haven't checked it yet. waiting for the correct Male Fitting. I have read that it should be read from the loader lift line on the tractor. And of course, just to keep things confusing for us novices, others have said that it should only be done with a "T".
Which is correct?
Al
9,577
Which is correct?
Al
Either will give you the same readings, it's just with the Tee you will have to max out the loader movement to get the reading. ;)
SidecarFlip
Banned
562
Any chance you can take a picture of this in the service manual? Someone on Facebook is disputing this.
Gee, who to believe, they guy who works on them all the time (Wolfman) or some yahoo on Farcebook. Obvious answer to me. Maybe not to you however.
Dgas47
Kubota B2601
Nov 28, 2018
27
McKees Rocks, PA, USA
Though I appreciate sarcasm, I definitely don't appreciate being insulted. I know who to believe.
The proof was needed to settle a dispute. Turns out the other guy's proof was from a BX manual instead of a B. If I had a service manual then I would have settled it myself. I don't so I was requesting someone who does.
Sent from my XT1710-02 using Tapatalk
Petey Kubota
B2601 Kubota loader back hoe
Milford PA
I have a Kubota B2601 with a FEL and pulled the hydraulic pressure is 2000. Says max should be 2385. Is it worth putting a shim in to gain the 300 plus pressure or could I go up to 2500?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
523
208
CNY
Isn't the upper limit for the main relief valve 2000psi?
