Kubota rear remote complete set-up
Ruskyhog
26
Wills Point, Texas
I have a complete set-up to put on a rear remote on my L4600 that didn’t have any remotes when I bought it a few years ago. I have since sold the tractor and replaced it with another. The parts are still in the box, not sure what other models it will fit. I paid $900 from the local kubota dealer and will take $750 obo. I will get pictures tomorrow when I get home from the fire station.
Willing to trade for some implements!! Let me know what you have.
Thanks
Josh
200mph
Mar 3, 2017
1,229
66
PA
Rustyhog,
Just trying to help your cause in selling the remotes... Info came from the wholegoods price list Jan. 2016 and prices from Hoober Kubota
L7231 Fits L3301, L3901 and L4701
Description: One rear remote valve – any position.
Valve Type: Spring Center Valve, Not detented or self-canceling
Optional Kits: L7211 1st Position Kit, L7212 2nd Position Stacking Kit or L7213 3rd Position Stacking Kit $175 at Hoober Kubota
L7221
Description: Lever Kit - First Position - Does not include valve Requires L7231 Spring Center Valve or L7232 Float Valve or L7233 Self -Canceling Detent Valve to complete. $557.75 at Hobber Kubota http://www.hoober.com/kub-l7221a-1st-position-lever-kit
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
I bought this from Ruskyhog. It will not fit my L3901.
The adapter block that comes in this kit is for an L4701 and it will not marry up to the L3901 ports. Finding the correct adapter block is almost impossible because Kubota parts arent listed anywhere that I can access on the internet. The parts counter at my dealership cannot find anything other than an entire kit to fit my machine.
The part number that I have [adapter block 77700-05645] is correct for an L4701 but it does not fit an L3901.
If anyone knows the one part number that fits in that spot....would be greatly appreciated
200mph
Mar 3, 2017
1,229
66
PA
This MIGHT be it...
#77700-05666
BLOCK,ADAPTOR (L3901)
$235.14 /unit
See private message.
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
Got tired of fooling with it. Ordered the complete Kit for my L3901 from Hoover tractor. So If anybody is looking for a kit for the L4701 tractor I have this complete kit $700. Right down to the wire ties.
TexasBoy
Kubota M7060 HDC12 & L4600DT
Dec 11, 2013
117
10
Central Texas
Im interested. Shoot me a PM when you have time.
Cotton Top
Kubota L4701
Nov 18, 2021
Alabama
I'm having the same problem, trying to get a part number for the assy cover plate for the L4701 to install rear remotes.
7,287
T
The old kits described here have been superceded. Go to Kubota parts online and look up the l4701. The new kits and components can be found under the Options tab.
Cotton Top
Kubota L4701
Nov 18, 2021
Alabama
Finally ran down the part number for the adaptor plate for rear remotes. This number fits the l4701 Kubota
Part number: 77700-05645
Cotton Top
Kubota L4701
Nov 18, 2021
Alabama
I found one and is on the way now. I have two valves one for the top link and the other for the side link. I made the end plate and the levers. I have two cylinders that I will modify for the top link and side link. If you need the company name I bought from let me know and I will post it.
7,287
OK - now I got it. You already had the OEM valves and need the adapter to hang them..
I am doing something similar for the L2501/L3301/L3901 except I am using aftermarket valves and making a custom manifold to adapt them to the transmission. I would love to do the same for the L4701 but without hands on access to a machine getting the fit right would be next to impossible. One of those L4701 blocks would make a nice starting point for getting measurements but the price is a little too high to experiment with given the work that would have to follow. Messick's lists it at $231.
Have you seen this video? The original remote valve installation on the L4701 was a bit if a bodge,
