Tyre ratio L3450 GST
hope to float
L3450
Feb 18, 2018
474
61
Ireland
Hi Guys,
The tyres on the rear of my tractor are way oversized (I think). They have a rolling circumference of about 150" (17.5 - 24)
What is the correct ratio for this tractor because I need to change the fronts and can't see any size on the ones that are on it? They are some sort of Bobcat tyres.
Thanks
6,369
Factory R-1 Tires were:
Front 7-16 RC @ 88
Rear 12.4-24 RC @ 138
So with R-4 Tires
Rear 17.5-24 RC @ 145 (This was the average of several manufactures)
Fronts should be RC @ 94
Look at the front's again and see if you can find any Numbers that might be a size.
I have odd sized tires on mine, they are shorter but fatter, works fine and dandy, better on grades and hills too.
hope to float
L3450
Feb 18, 2018
474
61
Ireland
Front 7-16 RC @ 88
So with R-4 Tires
Found it! 10-16.5 industrial tread. I will hopefully change to Ag tread
6,369
The RC on 10-16.5 is @ 91 so right now your ratio is off a little as it is, but it does work.
R1's are going to be much narrower that I think what you would really like to have.
Don't you want as much flotation as you can get out of it?
If you do, I can tell you the R3 or F1 Tires that will fit it that will give you much better traction, if that's what you need. ;)
hope to float
L3450
Feb 18, 2018
474
61
Ireland
Thanks North Idaho Wolfman,
I am trying for a combination of flotation and traction. All I can see are industrial skid steer tyres so any help would be great. Bear in mind that I also need to be able to carry around half a ton in the FEL but that is only for short distances, so not critical. I have been blaming the square edges on the fronts for digging in but it might just be because the ratio is out.
Thanks
