I have a BX2380 with just shy of 200 Hours on it. I took delivery in late March early April of 2017.
Since about 2 weeks of owning the tractor I have had a starting issue. It has been hit a miss and it won't do it at the dealer or long enough to properly diagnose the problem.
Every now and then when I try to start the tractor I turn the key and the indicator lamps come on as well as the fuel pump. Turn the half notch and the glow plug lamp comes on. But every now and then in the start position there is nothing. It might do it once or as many as 8-9 times.
Doesn't matter if the tractor has been sitting a few days or shut it off a tried to restart during a job.
It been back to the dealer multiple times. But will not do it there or long enough for diagnose myself.
The dealer has been great trying to resolve the problem! But so far just chasing a ghost. The last time it did it on the trailer taking it to the dealer. So a ran in and got the service MGR and the tech. But then started fine!
They have cleaned and double checked all of the connections and replaced the starter relay. This time they added a relay to hopefully find out if it does this again it will isolate to a safety switch.
I have even taken a video on my phone showing that the brake was applied. The trans was in neutral and the PTO was off.
I had a problem with my Kommander zero turn a few years back where dust and grass would get into the parking safety switch. After a couple of trips back to the dealer they found that JD used the same switch only with a dust boot. So they replaced with that and fixed my problem.
So I'm wondering if it might be similar? But on the tractor it has done it many times if I had been mowing, grading or even moving snow!
I love the tractor but this issue is starting to get OLD QUICK!
