It's a 2014 BX2370 bought off the used lot of a John Deere dealer in Kentucky. Since it's seems to be an expectation that you post pictures, I've attached a pic of mine sitting on the trailer on the way home...in the rain.
Anyways, since I spent nearly everything I had free to buy it, I need to find a cheap way to add ballast. I'll be using the FEL to move concrete this coming weekend, probably 400 to 500lbs at a time. I was thinking of using free weights on a bar extended across the two bottom points of the 3pt hitch but wasn't sure if the weight should be supported by the 3pt hitch of if it needs to be on the frame somehow. Can anyone give me an opinion? Also, given the amount of concrete I'll be moving at a time, how much weight should I add to the back end?
One more thing, what kind of diesel should I use? On road? Or off road?
Thanks for any/all opinions and I'm happy to finally be a real part of the group!
Rich
Rich
