Changing radio in a L4610
mopar2ya
104
ontario canada
I am having a hard time removing my radio from the overhead panel. It is a pioneer cassette deck and I want to upgrade. I removed face plate and inserted a plastic tie strap in both sides like I have done before to release the radio from its frame...did not work. I then searched for an hour and found the "proper" so I think metal tabs to release the radio....it would still not come out....any idea's?
Kanook
Kubota B2650HSDC Kubota RTV900
Jun 29, 2015
32
Almonte, Ontario
I don't have an 'L' cab tractor, mine is a B2650, but when I swapped out my Kubota radio for a Pioneer deck For some reason (which escapes me now) I had to remove the 'cap' of the roof in able to remove and install the new deck.
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
My l4630 radio needs to be accessed from the cap side. There are a number of long machine screws in the cab that hold the cap on. Just look around and you will see them.
mopar2ya
104
ontario canada
Ok I see about 10 screws, if I remove screws how heavy is the headliner? I was thinking I would use ratchet straps around the roof to let it down easy. Will anything else come apart? Heater tubes, wires...etc. thanks
200mph
Mar 3, 2017
1,228
61
PA
I'll quantify this first by saying I don't have experience with a L4610, but the Cap on my L4740 is very light and comes off with nothing else attached. I hope yours is as simple.
A second person is nice to have when removing, given its size and you'll likely need to use a ladder.
Not all bolts need to be removed around the perimeter, but can't remember which ones can stay in. Again this is referencing a L4740.
Hopefully someone with a similar tractor will comment.
ClayRogers
L4610
Nov 6, 2023
11
Midwest, USA
Just curious how things went with removing the cap on the cab? I need to do something similar.
5,214
1,894
take the roof off. Easy. Then you can get to it no problem. It's a good idea anyway, because where the back of the radio sits is kind of in a recess in the roof, which is easy to pinch wires in. If you have the roof off when you are installing, you can route the harness wherever you want it, so less chance of damaging wires.
Donystoy
Dec 10, 2013
567
217
Binbrook, Ontario
Removed my roof last winter when I installed the radio in my LX2610. Removed required bolts on the inside and a couple on the rear corners outside if I remember correctly. I just lifted up the one side and held it up with a piece of 2 x 4. Just had to bend over the clips on the sides of the radio that keep it in place as well as tucking in the wiring harness. Overall a simple job.
