Interim report on 3-point hydraulic refresh
If anyone is considering doing this on a B7300 or similar Kubota, a couple of things to note.
After twenty years the bolts that hold the hydraulic controller assembly to the base became corroded, I was lucky they didn't snap off. I am using new replacement bolts when I reassemble.
The linkage is a pain to get loose and out of the way. Same with the delivery pipe, I used a 1X2 length of board to hold it back out of the way.
I needed a two foot breaker bar to loosen the top link bracket bolts.
The most difficult connection was the Fulcrum shaft and its controls. I ended up pulling the controller assembly off so that I could slide the control lever off the shaft. Awkward but it worked.
I was told the casting weighed 60 pounds, not true, I weighed it on the bathroom scale, it weighs 42.8 pounds. That’s still heavy. I used a piece of nylon rope tied to all four corners to lift it off the housing and carry it over to the work table.
Planned to remove one arm to slide the shaft out of the housing with the other arm but realized quickly I was not going to be able to pull the arm off the spline. I gently knocked out the retaining pin on the (interior) hydraulic arm and then lifted the rod out. Finally, the piston came right out with a brief pop of air in the controller forward hole. Watch out, it comes fast, be ready to catch it with something soft. Mine nearly fell to the concrete floor.
Pictures attached if you are interested.
Question for the knowledgeable techs... looking at the piston pic, you can see marks (grooves) at the top of the pistons side wall and near the bottom. I see the same type of marks in the cylinder, no pic. I also see in the pic some nicks in the o ring. With the o-ring and retainer located near the middle of the piston I wonder if it rocks/pivots in the center and so, the top and bottom edges of the piston brush against the cylinder walls as it goes up and down?
Is a new o-ring and retainer ring going to make a difference? I don't see myself replacing the entire casting and I'm not too anxious to attempt to hone the cylinder. Thoughts/suggestions?
Thanks all, Roll
