Best Money Spent on a Shop Item?
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
So the other shop thread in the off topic section got me to thinking about all the do-dads I have in the garage. The other day I was using one specific item when it occurred to me that it was one of the best things I'd ever spent money on for the shop.
What was it?
The auto-darkening welding helmet! Should've bought one a looooong time ago!
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
They are one of the greatest inventions. To me it is almost a must-have when it comes to TIG welding when you are holding the torch in one hand and filler rod in the other.
Yooper
3901 LA525
May 31, 2015
1,660
804
NE Wisconsin
I wish they would have been invented sooner! I am convinced the arthritis in my neck is a result of flicking the old helmet down umteen times a day for many years!
William1
BX25D
Jul 28, 2015
1,245
444
Richmond, Virginia
Air compressor.
I have a 'cheapo' Craftsman oiless. Noisy but with a 30 gallon tank and 130 PSI, it does everything I need it to do.
All the other tools just make jobs go faster. The compressor makes many jobs possible that would not be able to be done with hand tools.
3,170
4,311
Im with you foot I need light,, a couple 4 foot LED fixtures hung up,, I found stuff I didnt even know I lost
9,266
It's a toss up between three.
60amp Plasma cutter, blows right through 1/2" and 3/4" plate like butter.
3 cylinder 5HP 80 gallon LaPlante compressor, I spray paint, and run a lot of air tools and this keeps up with everything.
And one of my newest tools a 9x20 Enco Metal Lathe from Lil Foot
I haven't gotten to use it a whole lot but the times that I have it works perfectly.
I needed a couple odd size pins and I was able to make them and really get the slop out.
Thank You Again, Lil Foot! :D
PHPaul
Apr 2, 2015
1,191
1,375
Downeast Maine
www.eastovershoe.com
Pretty much anything that provides power (pneumatic, hydraulic, electric) to what used to be a manual task. Could be as simple as a battery-powered impact.
I bought a ~ $100 Harbor Freight 110v hoist and mounted it on a trolley-style barn door track on my ceiling. Runs from the overhead door in the front to my workbench on the back wall. Makes it a LOT easier to get stuff up on the bench to work on it.
Video
bearbait
Dec 9, 2011
4,126
888
New Glasgow Canada
All the above, I do use the mig welder a lot and couldn't do without my compressor but definitely lacking in the lighting.
3,170
I needed a couple odd size pins and I was able to make them and really get the slop out. Thank You Again, Lil Foot!
Glad it's working out for you.:)
I really like all my tools. The wife says I'm obsessed with them & says that I have more tools than she has shoes, which is a lot of tools. But if I had to pick, it would be task lighting; or the compressor; or the new lathe; or the 24" digital caliper; maybe the band saw; rotary table; pressure washer; 5C collet chuck; etc., etc., etc.....
eng1886trk
2016 B2650, 60" bucket, QH15, RB1572, LR1572, BB1260, 42" forks
Mar 9, 2016
76
Lancaster, PA
I'd have to say my ever growing collecting of DeWalt 20v tools. Use them all the time while it's a simple tool, I don't know where I would be without my impact drivers.
bearskinner
Sep 1, 2014
926
241
N. Idaho
Every time I use the lift I am SO happy I’m not working on the ground with a floor jack or stands.
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
I guess my best tool investment would have to be whatever one I am using at the time. Hand tools, power tools, pneumatic tools, cordless tools, custom tools made by manufactured tools..... First thing I do when considering a new hobby is to see what exciting new tools I would need!!! :D
For those who have lathes, a mill with plenty of fixtures and tooling is the 'yin' that follows the 'yang'! ;)
Tooljunkie
May 13, 2014
4,150
Lathe,plasma cutter, multi-process welder,drive on hoist. All the hand tools. Sandblast cabinet,the list goes on and on.
All the tools to fix whatever comes up is a necessity.
I dont have a must have tool list,as there are so many i just cant do without.
Having to justify an expensive tool is difficult, most expensive was my scan tool.biggest expense to date,and doesent earn me any more money than before i had it. It does speed up diagnosis for the most part.
Biggest and most important,a warm place to work in the dead of winter...
7,064
Probably sounds foolish, but I use my little 18v 1/4" impact for so many jobs, along with a couple different boxes of adaptors, bits, etc. for sockets, drill bits, torx...list goes on....
Doesn't matter type of job, always seem to drag that out for something....cars, tractor, carpentry - nothing to heavy duty, but works great.
That, and a variety of cheapo pneumatic die grinders, snips, nibblers, impacts. All are cheapies, but all have been so handy for occasional work. My wife uses them sometimes.
2,869
Shop Stereo. Nothing happens without tunes.
Amen brother..........
things move faster and mo' better to the beat!
classic rock.....sometimes a little too loud!:D:eek::)
8,650
Lets put a variable speed drill press on the list.
Got a floor mount industrial one given to me. Just gotta pick it up one of these weekends. Does need a new arbor. The existing one is worn on the shaft and tends to pop off when raising the bit.
