I just replaced the seals in the 3 PNT hitch cylinder in my b6200d, due to it leaking down. The new seals fixed that issue, but now when I am using the hydraulics, I am getting air bubbles in the fluid and just today it started overflowing fluid through the breather. It was white with bubbles but if you rubbed the bubbles the fluid cleared ( ie. no water).
When I replaced the cylinder seals, I did not replace the seals on the cap. Could this be sucking air in? Should I have filled the cylinder with fluid when I changed the piston seal, before buttoning it up?
Is there a way of detecting air leaks?
