My New Wood Hauler (Carry All)
5,559
That looks like you could put some cushions on it, back up to the lake and do some fishing in style!
Those kind of projects are mind therapy. Much cheaper than psychiatrist.:D
2,551
Nice carry-all
you think you need sides - or a removable side? or is the wood such it cannot fall out?
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
D2Cat easy now my wife is a Psychogist so too many projects like that and she is out of work.....
Creature Meadow
Sep 19, 2016
1,063
135
Only time I remove mine is when I need another implement otherwise it is too useful to leave sitting beside the others implements.
jajiu
Jun 5, 2016
456
112
Rowley, Massachusetts
The nice thing about the carryall is that you can design it for what you need. I can carry firewood, tools, just add weight, or whatever. Adding pipes make it so you can put landscape tools with long handles in or chain etc. It's all about fun. . . . . er work.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
344
128
St. Louis, mo.
Ok you guys convinced me , I need a wood carrier . Guess I'll be visiting tsc tomorrow
5,207
Steve - worked on me too!
But gotta get above 0F before I consider that project!
Also, my local TSC seldom has them in stock.
firefighterjohn809
Plymouth, IN
Sides are on and also just snowblowed for the first time. Worked awesome!
I like how you put your sides on a 45-degree angle which will really add some strength and rigidity, something to consider when I start building mine. But, it reduces sidewall height...decisions decisions...Lots of good ideas here from everyone's carry all.
Creature Meadow
Sep 19, 2016
1,063
135
I had a few weights laying around that I had no use for well until now. I use the carry-all as a ballast as well so I bolted the 4 weights under mine that added another 150#'s. Out of sight and out of the way but functional.
fishinroc25
Kubota BX1830 w/loader, custom front plow, 3-pt trailer hitch, Carry All
Apr 20, 2017
68
Rochester, NY
I used the Tractor Supply Carry All and built this:
Jajiu or Creature Meadow,
Would you share the dimensions of the box? I would really like to build one for my BX. Thanks!
