2012 RTV-X1100C block heater?
WVRick
RTV-X1100C
Dec 27, 2017
Salt Rock, WV
2011 RTV-X1100C block heater?
Hello,
I been trying to find the right block heater for the RTV-X1100C diesel. I'm trying to find one in the Kats brand and ordered the 11407 but when it came it was threaded and 1 1/4".
I think I can find one if I knew the freeze plug dia. or if there is a accessory port for a heater?
Thanks Much!
My mistake its 2011
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
I live where today it is -40 degrees in my opinion the best system is a circulating heater available at most automotive stores it works by installing the heater in the rad hose clamping it in there plug it in to power this will warm the coolant and circulate it through out the block best system so far in the north
good luck
1970cs
1,124
Grand Ledge
Re: 2011 RTV-X1100C block heater?
Hello,
Thanks Much!
My mistake its 2011
Why not just buy the O.E. for around $50? 70000-73595
If your local dealer won't help you please let me know if you need.
Pat
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,182
162
Hardisty, Alberta
Hello,
Thanks Much!
My mistake its 2011
The proper oem block heater for your machine is a drive in type that goes in the frost plug hole on the rear of the cylinder head. It works very well on those small engines
