Hello All:
B2650 cab
150 hours
Spreader on back three point
Snow blower on front
I have lift / lower function on three point
I have left / right rotate function on front blower chute (or bucket tilt when FEL is on)
I DON'T have any lift / lower function for blower
It is stuck in one position approx 3" off ground
Joystick in cab feels right for left-right control, but forward-back motion of joystick for lifting is just "loose", no resistance either direction, just sort of flopping.
Air in lines?
Loose cable connection from joystick to hydraulic valve?
Bad valve?
If anyone has a suggestion, I'm all ears! I haven't had to troubleshoot much on this tractor since I've only put 150 hrs on it, so not much experience fixing things.
If I can't fix this, I'll need to at least relieve the pressure on the blower up/down cylinder so I can get it to rest on the ground. We have large lake-effect snow on the way over the next three days, so I'll really need this thing!
Thanks everyone, enjoy Christmas!
B2650 cab
150 hours
Air in lines?
Bad valve?
