three point hitch on L1501
tom sangster
L1501,B7001 with front blade, BX2370 with front mount snowblower
Sep 1, 2017
Thedford,On., Canada
I am new to this forum but I am looking for advice on fixing the three point hitch toggle switch that operates the three point hitch. It will work sometimes, it seems to be affected by the switch beside it that controls how the three point hitch operates. Can we bypass that switch and just have it run normally. I have not found any loose wires but it only works once in a while. Tom
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
While I do not have a L1501, I do have an L1500 and I'm pretty sure they're the same, the three point hitch is strictly hydraulic there is nothing electric about it, can you please post pictures of what you are referring to?
9,117
I'm thinking he's referring to a Monroe-matic set up. Some other members on the site have posted questions on it before. But could never get a straight answer. Since no one on the site new the answer. Which the question was always "what do all these knobs and switches do?!!!!" Service department Vic does a good job explaining the mechanics of it. :D
http://www.orangetractortalks.com/forums/showthread.php?t=29722&highlight=Monroe+matic
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Ahh, never heard of that setup,
on found this on Tractor By Net...
This control is self leveling tilt control,
that is used with a tiller to maintain a level surface as the tractor moves.
It will hold the tiller level if the tractor shifts side to side as it moves forward.
The tiller mounds the dirt up and makes a flat surface about a yard wide, with channels between each row...
The left button in kubota blue, is the on/off switch.
In the center is the manual/auto selection. Manual on the top and auto on the bottom.
On the right are the left down, right down buttons, which I assume you use if you are in manual control,
or perhaps to for initial set up before putting the system in automatic.
By the way, this tractor had two rear pto speeds, I believe they were 540 and 1,000, and also had a
reverse selection, that the farmer could use to better move the earth as needed when he reached the end of the row
And this from OTT...
http://www.orangetractortalks.com/forums/archive/index.php/t-464.html
An interesting photo, probably not the same setup...
http://www.cj3apage.com/index/Accessories/monroe_3_point_hitch.htm
And on a Dodge Power Wagon 1947ish...
http://t137.com/ClintDixon/monroelift/index.htm
http://t137.com/ClintDixon/VintageFarm/index.html
tom sangster
Sep 1, 2017
Thanks Bill and Darren, for replying to my thread, yes the L1501 is different from the L1500 . The hydraulics are controlled by the buttons and toggle on the dash. Your description of what each button does may help me figure out what's wrong or I may have a bad electrical switch. I will try to put
a picture of the dash on a new thread. Thanks again for your help & I look forward to more discussion. Tom
7,629
Tom, I think you have to have at least 5 post before you can post a picture (to help keep trolls off the forum). So make a couple more comments/questions before you try posting and become frustrated.
9,117
Tom, your three point hitch controls are actually an option for the L1501. Not the norm for an L1501. The normal set up for the three point hitch control for an L1501 is a lever to the right of the seat :)
tom sangster
Sep 1, 2017
Thanks Daren, I also have a B7001 that has the hydraulic control lever on the right side of the seat, it is much easier to trouble shoot but we will get the other one figured out, it sounds like it is a good control once we get it working. Tom
