B2601 LED Headlights
msmcknight
75
Statesville, NC, USA
Hi Guys,
I'm looking to swap out the OEM headlights on my B2601 with brighter LED ones. I thought they were the same as GM 881 fog-light bulbs, but when I tried to use some, the plugs were different.
Does anyone know what the correct bulb/connector type is for the 2601?
Thank you,
-Michael
Juiced06GTO
2016 B2601
Nov 26, 2014
79
Sutton, MA
Pretty sure they were 1157 or 1156's I'd have to go check what I grabbed for mine. You will have to swap around the wires as LED's are sensitive to polarity and they headlight sockets on the B2601 are wired backwards from every other light socket i have ever seen with the case positive and the post negative.
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
I found some Sylvania Zevo 7506 bulbs that were a direct fit and a huge improvement over stock bulbs. I believe I bought them at Advance Auto Parts, but I cant find them online anymore....they used the 1156 base (BA15?) And had a domed, opaque end on them. My next attempt at better light will be a high output LED array mounted to brush guard. The FEL plays havoc with good lighting on front of tractor.
Shelbygt660
29
echo bay
Kubota should offer led lights. I know they do for the grand l series. Check with your dealer or if I remeber I'll check on Wednesday
Sent from my SM-G930W8 using Tapatalk
DuckDog
B2650
Jun 23, 2017
72
Laotto, IN USA
If you have a ROPS get one of these
https://www.princessauto.com/en/detail/13-in-led-light-bar/A-p8724312e
2880 lumens
I got mine when they were on sale for $79 - they are super bright and worth every penny. Fantastic for cleaning snow.
Have this on my quad they work great and can’t be beat for the price.
Auxbeam LED Light Bar 12" 72W CREE LED Light 24pcs 3W CREE Driving Light Combo Beam Waterproof for Off-road 4x4 Truck Military Mining Heavy Equipment https://www.amazon.com/dp/B00T7GYDTC/ref=cm_sw_r_cp_api_JHqqAbXCF3F4T
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
The bulbs as stated have an 1156 base. Any led with that base will work. I picked up a package of 20 on ebay. Only issue you may run into is that the led bulbs may require you to swap the wires. The led bulbs are polarity sensitive.
thebicman
Feb 2, 2017
333
97
Ottawa, ontario
This was one of the first upgrades I did on my b2601. I also added led floods attached to the grill guard. Amazing light while snow blowing from both.
TRA
B2601, LA434, BH70, LP BB1260
Dec 17, 2017
88
Rock Hill
Thanks for the bulb link.
I have been looking at short LED light bars to go on the front of my canopy. Lots of stuff on Amazon that looks promising.
coachgeo
Nov 16, 2012
2,460
35
Southern OH
There is a good number of LED upgrade threads to go through in here (in the fabrication/customize forum I moved this thread to) that you can grab ideas from. Check the huge thread ROP lights
bearbait
Dec 9, 2011
4,058
834
New Glasgow Canada
Well -15C can't stop us crazy old posties, lights came in and their on and I have to say I'm impressed. If they look this bright in the day they should be a major improvement after dark.
