Tractor is 2007 model...stills runs great...but will not move forward or backward when I let the clutch out...motor dies...think it may be a switch problem..anybody know what could cause this?
Parking brake? Gears not engaged properly? Mechanical problem? Fuel problem?Tractor is 2007 model...stills runs great...but will not move forward or backward when I let the clutch out...motor dies...think it may be a switch problem..anybody know what could cause this?
You also have a Seat Turn Switch that is under a cover behind the seat IIRC.have already connected the two wires together on the seat safety switch basically bypassing the switch and creating the loop.....didn't fix the problem...thanks for your advice...pretty sure its something simple....safety switch somewhere...most likely electrical issue...
