Weigth of new LA1153 loader
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
Does anybody know the weigth of the frame and then the 1153 loader when it is installed on a Model M7040 Tractor???
Just try to find how much this will add to the tractor!!!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Don't hold me to this but going by how much my loader weighs it wouldn't surprise me that a loader that size would add 2500 lbs.
moondog933
M7040,Landpride Cutter RCF 2784,FEL LA 1153,FORKS PFL 3048,John Deere MX10
Jul 26, 2013
15
oberlin, la.
was wondering this myself, nowhere on the spec sheet of the FEL does it show the weight. Is is already added the tractor weight ?
Bulldog
Mar 30, 2010
5,440
78
Rocky Face, Georgia
My LA 450 S loader on my L3000 weighs 1250 lbs, that includes the bucket.
The weight of the tractor doesn't include a loader on the specs.
CFDWheeler
57
Grant Co, Ky
It is roughly 2200 lbs with the bucket. I remember reading it in the manual; Ill try to confirm when I get home.
CFDWheeler
57
Grant Co, Ky
Ok, I was slightly off. Briefly perusing my loader manual I found that the loader and bucket weight "approximately" 2006 lbs with the 72" round bucket.
I think i read elsewhere that the bucket weighed around 700 lbs, but am still looking for it....
moondog933
Jul 26, 2013
15
oberlin, la.
Thanks for the info....If I would have brought all my new tractor manuals to work with me I would have seen that :)
KubotaL185DT
L185 4x4, L245H, M5140HD, Case 580B Hoe, JD350 Dozer, JD LX178,
May 6, 2010
81
Northern Calif
I realize this is an older thread, Does anyone know how much how much the the 72" round bucket does in fact weigh ? The one that comes with the LA1153 loader. Thanks Bill
KubotaL185DT
May 6, 2010
81
Northern Calif
With or without the bolt on cutting edge?
Pat
Without a bolt on cutting edge, My bucket has no holes for a Bolt on bucket appears to be a run of the mill General Purpose bucket I would guess it weights abt 400 lbs
KubotaL185DT
May 6, 2010
81
Northern Calif
The L2296 QA HD bucket without the bolt on cutting edge is #400.
Pat
Thank you Pat, Boy my guess was correct I better go and pick some lottery numbers Thanks again Bill
etpauley
Kubota M5140 hyd shuttle
Apr 23, 2015
clarks la
Does anyone on here have a WR Long 3rd function kit on their LA1153 loader going to
put 1 on my m5140 would like any info and pictures that you care to share . thank
