l3800 runs good then rough
sherman spanner
l3800, bx2200
Dec 10, 2017
albany, ny
my l3800 has consistently had a problem for a while where it runs great then loses power runs rough sometimes stalls then runs fine, no problem with fuel getting to filter it runs full flow. I have run at least 5 tanks of fuel with power service additive and changed the filter 4 times. What is the little knurled knob where the fuel return line comes from injectors, it appears to adjust a needle valve could this be part of problem. Also why can't i find a shop manual for this tractor, is that privileged information for Kubota Technicians?
2,551
What Teg points out is the bleeder valve - just as you mentioned, when you run out of fuel and need to bleed the system. No needle valve under, just allows air to escape.
How about the air filter, have you checked that by chance? How long does it run then run poorly after running fine? Have you removed the fuel tank filler cap, it could be a vapor lock.
Sammy3700
Feb 20, 2012
437
41
Red Springs, NC
As far as I can tell the L3400, L3700SU and L3800 are the same running gear. The L3800 is wearing a new Sunday dress.
sherman spanner
l3800, bx2200
Dec 10, 2017
albany, ny
Thanks all, I think the bleeder was open slightly...duh. I pulled a massive tree out of the woods today and had no problems. hope that is it. Thanks for the wsm part number also!!!
Flynlow3
Kubota L3800HST land pride rcr1872 woods rd7200
Aug 29, 2017
Effingham IL
If your tractor runs rough after it is under a load, it could be starving for fuel. Check that your water separator is in correctly. If upside down, fuel will flow over the top and it will run great until it's under a load for a period of time. It will starve the resevor and start to run rough.
