Parts (hoses) Kubota or generic
RobCJ7
12
NM
I bought a B1750, that needs some replacement hydraulic hoses, not the ones for the FEL, but the small ones that connect 2 metal hydraulic lines together, for the hydraulic oil cooler.
These are expensive pieces of rubber, just wanted to know are these a special diameter, or can I get this hose at an auto parts place
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
Re: Parts (hoses) Kabota or generic
I don't think you will find them at a parts store but you must have a place locally that can fabricate hydraulic lines? Take the lines off and have them replicated.
RobCJ7
12
NM
These hoses are just couplers, they are held on my regular hose clamps, about 3 inches long.
Not your regular hydraulic lines to your implements with a fitting on the end.
Here is the link where I can buy them, but holy smokes they are expensive
http://www.messicks.com/part/66204-36270/hose-27-x-15
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
If they are suction/ low pressure hose joiners, most bearing shops will have high temp hose to suit, I doubt you'll get suitable quality/size stuff from an auto store but you may be lucky, otherwise hyd shop.
BAP
Dec 31, 2012
2,758
873
Most good auto parts stores, farm equipment dealers or anyone who deals in hydraulics should carry bulk suction and return hose sold by the inch. Take a piece along to have it match up.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
27x15, that sounds metric to me. If you try a parts store, I would mention the 27x15. They might come up with it, or you will get close, might work.
Sent from my LGMP260 using Tapatalk
RobCJ7
12
NM
Ok this sounds good, never thought about asking the hydralic shop, now I know what the house is called (suction & return)
