L5740 wire connector at left cab pillar... what is it for?
HorsPower
Kubota L5740 HSTC-3 Cab
Nov 5, 2017
24
12
Maryland
Check out the attached photo. My (new to me) L5740 has this two wire connector stubbed out from the left Cab pillar. Can anyone tell me what it might be for?
The tractor has all of the optional dealer installed items that I am aware of (defrost windows, front / rear wipers, front / rear work lights, radio, etc). Also, it does not appear that the previous owner had any third-party accessories mounted in this area.
Thank you,
2,891
How about a small fan?:)
2,891
Certainly possible, however I was thinking maybe it was a factory provision for something OEM / dealer installed.
This is supposed to be a wiring diagram for the L5740.....
fuzzy however - not sure it helps:)
HorsPower
Nov 5, 2017
24
12
Maryland
2,891
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Do you happen to have a link to the LXX40-3 WSM manual (or are there any significant differences? )
I don't have a link for the -III, here is one for the -II
https://www.manualslib.com/manual/1063184/Kubota-Wsm-L3540-Ii.html
If you have a -III, please update your signature line to show it and also reference the -III whenever asking questions. There will be differences.
Send North Idaho Wolfman a PM, he may have a -III manual if that's what you have, worth the ask anyway.
Did you look at the colors of the wires on the Cabin diagram and work it out?
