I was changing the hydraulic oil and filters today on my B26 and noticed that 2 ports were leaking out of the control valve that sits behind the rear passenger tire. I know very little about hydraulic connections so this is where I need the help. Both of the leaks were coming from the threads that go into the control valve itself not at the flare connection from the hose ends. So I removed the fitting and it is a 90deg fitting that has a nut and some type of black compression type sleeve on it that I assume is what is supposed to seat and keep leaks from happening. My question is should I just replace the whole fitting or Is that compression type sleeve replaceable? What do I ask for(what are these parts named) when re installing these should I use some type of thread lock or sealant?
