FEL color functions
bodieflhr
BX25 mower backhoe FEL leaf collector snow plow
Oct 29, 2017
Julian pa
I have a BX25 and recently purchased a used plow and hydraulic subframe. None of the hose that came with the plow are color coded.
There are 4 male coupler ends on the tractor, red, white, blue, and yellow. What I need to know is their function.
For example which color lifts the FEL which color puts down pressure on the FEL. Which color rolls the bucket down and which color rolls the bucket back up. If I knew that I could hook up the plow. Thank You
2,913
Looking this up .....
Try these and see if it works;):)
1) Tractor yellow valve block to the bottom hose of the VERTICAL blade cylinder
2) Tractor red valve block to the front hose of the HORIZONTAL blade cylinder
3) Tractor blue valve block to the rear hose of the HORIZONTAL blade cylinder
4) Tractor white valve block to the top hose of the VERTICAL blade cylinder
bodieflhr
Oct 29, 2017
Julian pa
So based on your reply yellow raises the FEL. White lowers the FEL. Red and blue roll the bucket. Of those 2 which one rolls the bucket down? That would be the one that pivots the plow to the right.
9,769
Let me take a wild guess... your having problems with it turning? ;)
2,913
See if this helps - not 100% of original post
this is from the manual:
