Hi,
The RC60-72 mower deck under my new to me B7200 needs a little attention. The front gauge wheels have worn out their bushings and have also worn notches into the shaft. The Kubota dealer was in the $400 - $500 range on replacement parts, so I want to try making something myself.
I plan to cut off the worn shaft and weld a new one onto the yoke piece. I have been looking for wheels with bearings in McMaster Carr as well as the steel shaft to make the new axle. The original wheels measure 6 and 1/8" diameter and 2 and 1/2" wide. My question is would a 6" diameter X 2" wide wheel work OK, or should I be looking at something wider? What about bearings? I can find both straight roller bearings and ball bearings in the wheel size I am looking at, which should work better?
Thanks
Tim
Thanks
Tim
