New tractor - fuel additive
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
For good fuel maintenance Im currently using a fuel additive in my old L245.
If I was to buy a new 2017 tractor, do you still use additives on your new tractors ?
2,609
Additives for lubrication....perhaps not, additives for algae and other stuff??? I still would!
My 2013 Bx purrs very nicely with all that good stuff added!:D:)
BAP
Dec 31, 2012
2,821
931
If you run actual Diesel fuel in your tractor and not just #2 fuel oil, you shouldn't need additives for lubrication. Diesel fuel already has additives in it for lubrication.
Brazos
L2501DT
Jul 12, 2016
122
I have been using them only because I do not put a lot of hours on my tractor so it sits a lot. My first year i put 32 hours on it. I am a weekend warrior and may go a handful of weekends where I have other things going. So I try to keep my tank fuel (to combat condensation) and use additives to keep the fuel fresh and algae free. If I ran it regularly I wouldnt bother because I would always be putting fresh fuel in it. Just my thoughts and may be wrong.
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
320
26
23
Mobile, AL
I've always used it since I bought my tractor new. My tractor sits a lot too and I've never had a problem. I also filter my fuel. I plan to stick to the same procedure.
mickeyd
Mar 21, 2014
1,192
Guin, AL
What additives do you use?
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Sounds great. Thanks
I buy it at our local Loves Travel Truck stop so its called #2 I believe.
Thanks
Sounds like a safe idea.
Thanks
As long as it works thats great.
Thanks.
Opti-Lube XPD ever since Ive owned the old L245. After engine is at full operating temp, I swear I can hear a distinct pinging sound in the engine when I dont use it.
Creature Meadow
Sep 19, 2016
1,064
136
Central North Carolina
I use Power Service Diesel Kleen the white bottle in the winter and grey bottle in the summer.
Does it help I cannot prove it but I do know I have had no problems fuel related since taking recommendations from here to use it.
It is cheap and insurance to me. I have a measuring container that has ounces marked on it and I took a black marker and marked where to fill for my various containers, 1 gal and 2.5 gal containers. I use 1 ounce per gallon.
Here is a link to the Power Service website, it can be purchased at most any auto parts store at least here in NC.
http://powerservice.com/psp_product/diesel-kleen-cetane-boost/
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
I have a 55 gallon drum of off-road diesel that I just had filled about a month ago. I don't believe I'll go through all of it before the end of winter so I'm wondering if I should add the winter stuff (white bottle) to it or just go with the grey bottle year round.
The filled drum is stored in my uninsulated attached garage.
Sent from my SM-N920V using Tapatalk
2,609
In your neck of the woods, I would add the appropriate amount of winter stuff just to be on the safe side. ;):)
Oct 8, 2014
623
oregon
Talk with your local fuel supplier, they're all the same thing. On the other hand a friend who runs a large diesel repair shop swears by lubricity additives, he's got a favorite but that's another can of worms. His point is modern high pressure fuel systems have such tight tolerances it helps. It's a 14K repair if you crater a SuperDuty fuel system, cheap insurance.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Thanks and glad for your positive input.
Noted. Thanks for the reply.
